Statistical Analysis System
The Statistical Analysis System was an American system for PCs and QLs which allows you to perform statistical analysis. It was designed to take test data and calculate Pearson III statistics of mean, variance, standard deviation and coefficient of skewness in the normal way.
This is then translated into the Weibull parameters of Weibull slope and characteristic life, whilst accounting for unfailed items in the test samples by assuming they are Normally Distributed. If the number of test tiems are less than 30 samples, the syste, allows a choice of a Maximum Likelihood Analysis.
(MISSING IN ACTION)
Title: Statistical Analysis System
Language: Unknown
Author: Glen Ernest Smelcer (1931 - 2006)
Publisher: Mechanical Design Analysis Consultants MeDAC
Year of Publication: 1992
Price as at September 1992: Unknown
Commercial Status: Commercial
Reviews: Unknown
Sources Available from: n/a
  • qlwiki/statistical_analysis_system.txt
